hi
(In Topic #108767)
Hello from crazymonkeyboy
the wheel pcd etc, dimensions of the boot, what is the biggest or most powerful engine that you could put in a mk1 it has to be a snug fit though as i dont want it all cluttered , as i will be using this as a show car hopefully by next year.
i've just moved your post from someone elses "newbies" thread,
just so everyone else can welcome you properly.
Dean
Sounds like you've got some big plans for the car already! The wheel pcd of Mk1 Golfs in 4 x 100. The boot is 13.0cu.ft/260litres…not sure about the measurements though, is it so you know what sound system you can cram in? As for your engine question, I would post up in the technical sections for some ideas, with the 1.3 being a small block you would have to change the engine mounts to put in a big block.
Crayzeeeeeboy
I am learnin every day and enjoying it .
Regards
B
You've certainly come to the right place to learn, lots of expertise on here!
Be sure to start your own project thread when you get your MK1 so we can all see your progress!
