help needed
(In Topic #132748)
help needed
Hi there anyone.
just about to remove the rusty filler neck on a my pride and joy.When she is all of is should i remove the tank to wash it out or flush out injectors with an additive at a later date bit confused as new to this classic car game .Seen the link saying walk away if you have seen a car with rusty filler neck also seen one saying a common fault
Tony
Hi Tony,
It is a common problem for sure, replace filler neck and flush the tank.
Stick a post in the tech section if you aint already and someone will help you out quick snap.
Welcome to the club by the way! :mrgreen:
Welcome to the club Tony. It is indeed a common problem as the ceck runs down the arch and therefore corrodes quicker than most places. You can experience problems in the tank, fuel lines and injectors if you have a rusty filler neck. To be safe I would replace the fuel lines, fluch the tank and replace the filler neck.
Welcome to the mk1 family mate and if you get stuck post in the technical sections and I'm sure someone can help :wink:
