Golf MK1 carb problem?Fraustrated
(In Topic #114967)
The idle is erratic when cold but solid when hot until it cuts out and speeds up as engine gets warm. Need to keep revs up at junctions etc. The car is great otherwise but makes me long for a good old flat four air cooled.
I am in Botley near Southampton. Any suggestions appreciated. Might it be sucking air from carb base/gasket.manifold gasket? Would that explain the speeding up of idle when hot? It has been suggested there might be a hole in an idle diaphram? Cannot even work out what this carb is as it does not seem to be the usual Golf type? CAnnot find a four hole carb base plate all seem to be three.
Fraustrated and fed up by the whole thing. YOu might be my last hope.
