Golf GTi 1.8 1990 Great condition Garaged 20years plus
(In Topic #230669)
Just carrying out a few jobs to get it up to scratch keeping it all original where I can. only real mods are period wheels and upper/lower strut braces.
car on 135k miles
loads of history owned once by Barings bank. Also was Black with a grey hood now Corrado blue.
jobs completed so far are:-
car on 135k miles
- Alarm immobiliser removal
- All fuses replaced aligned with recommended ampage
- Fixed a draining battery turned out to be retro fitted electric windows off 12v permanent now on ignition
- Door pins replaced and drivers door aligned
- 3 point rear seat belts fitted
- New carpet mats
- Clutch release bearing and cap replaced
- Clutch cable grommet guide and fitting kit
- Boot trim secured with A4 binders
- 2 month old cracked tyre replaced under warranty and leaking tyre re sealed
- Misted full beer lamp on the inside cleared
- Stereo wired from 12v to ignition
- Cigarette burn fixed on chair professionally
- A few rattles and squeaks resolves
Last edit: by Pcundy
Car Golf 1.8 1990 GTi Cabriolet in Corrado Blue
(Was Black with Grey hood) 135k miles. Original number plates and dealer rear window sticker.
Owned by Barings Bank at one point. 5 Owners from new. Off the road 2010-2020
Picture of Fuses before and after
Crazyquiffs 3 point belts that came with the car now fitted
Boot trim repair using A4 binders at the top.
Alarm removed
Cigarette burn repair
new mats
new mats
VW/Audi in Bradford On Avon have replaced the manifold / exhaust mesh gasket and clips. It was that on acceleration, gear change and backing off causes a squeak/ chirp. Will keep an ear out but hopefully the noise has stopped.
Item purchased
https://www.ebay.co.uk/itm/172244466129
Replaced with
Item purchased
Replaced with
Full been light de mist from the inside second light in from the left below.
How did you clean the headlights?
Regional Host NE
lift the three fold over tabs remove the bulb holder
bit glass cleaner and a microfibre coth well thats
how i did mine
how i did mine
How did you find this kit for fitting and durability/safety? Considering getting it for my Cab as I need it for child car seats.Pcundy said
There are a couple of metal tabs at the back of the headlight, prise these open. Ideally remove the headlight to do (I didnt). Then find a soft cloth to put on a stick or screwdriver. Then I just used window cleaner
Brilliant Kit very sturdy several mounting points on it.. also good shoulder height on the seatbelt.. Was nervous of cutting the metal by the parcel shelf at first but there is a template with the instructions.
So you split the glass 'lense' from the silver 'bowl'? or just removed the bulbs?
Remove the silver ring bulb side.
Not the neatest job but should save the rust. Removed the push switches from the old alarm filled and painted.
So did the bounce test on the rear of the car test and shocks have gone. Have ordered these and some lower bolts. Part number bolt - 010 470 1(m10x70 ) Nut 102 090 09 ( m10)
http://www.heritagepartscentre.com/uk/171513033p-rear-shock-absorber-oil-filled.html?gclid=CjwKCAiAoOz-BRBdEiwAyuvA63CM3e1NbR0DZtW2zuAtvv5V5xaPqpmEL4s9I0ho9aMfOhB-fcGj-hoCd7gQAvD_BwE
After searching for boot carpet other than paying £40 decided to do a diy job. £12 for car carpet delivered enough for 4x layers meaning underlay/sound proofing not required.
Clean up in the boot and space saver tyre pressure check to the recommended 60 psi
Wobbly seats sorted today
Plastic parts for Seat runners 2x of each parts 171 881 213 B & 191 881 213
Easy job Phillips screw for runner cover behind front seats to be taken off. Then bolts front Centre of front seats. New parts fitted greased and refitted.
