Gearbox oil everywhere!!!!!!
(In Topic #125921)
Also problems with the gears, it jumps out of 5th and reverse and doesn't like 3rd. Changed gear linkage bushes and set up the 15mm gap under the gear stick still no good-wondered if the problems might be related i.e no oil in box.
Thanks Matt
Web Team
gen78 said
The one on top of the gearbox coloured green with a push in cap.
thats the cap for setting the timing , not the gearbox oil , you fill the gearbox oil by removing the speedo cable or the 17mm alloy key plug at the side , it cant be done in a carpark unless you have tools,jack etc & you must never overfill it.
Im not sure of the consequences of what you done , chances are your clutch will now be contaminated
Web Team
Have a read of the following link and that should sort out where to top it up. Your symptoms do sound like low fluid level.
020 Oil
Very difficult if not impossible to get the oil out off the clutch.
gen78 said
That explains one or two things, thanks for your help. I'm gonna find a rock to crawl under.
why? We all make mistakes mate that's why the website is here… to try and help people recover any issues and be part of a community… don't hide… get posting and join in… you certainly aint the first to do that and you won't be the last :wink: …. I guarantee it.
