Rear axle mounts
(In Topic #236012)
Probably should of pictured that before stripping them down!
Also once the bushes are in which hanger goes to which side? Flat edges of the hanger outer or inner?
1989 Paprika Red 1.8 Clipper Cabriolet
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Frunning-gear_2%2Fwhich-way-round
Thanks for the advice, what a great thread you have created and a beautiful car.
I'm further on now and looking to put parts back on today hopefully.
I've put a standard set on mine, not sure what you have there but the washers married up with a slightly more dished shape fitting better to the bush…if that makes sense. Don't think it would make much difference as long as you can get it all back together and torque it right.
Good luck
Ollie 55 said
Daz,
Good luck
They are super pro poly bushes, I agree I don't know if it would make a difference but I thought I'd ask before getting it wrong. 🤯
Briano1234 said
Insert the rounded end in to the mount on the right side of the mount in picture 1. Use Grease in the mount to ease the thing in.
I had a go and failed massively!
I used a threaded bar to pull them in but they refused and just squashed 😂
1 bolt that is 2 1/2 times the length of the Bushing.
1 Nut that fits the bolt.
One large Socket that fits over the mount hole and has some room to spare.
Grease the inside of the mount and the bolt.
Place the Bushing in the hole, place a large fender washer on top, insert the bolt through the bushing and
Insert the bush into the mount, then place a washer on the other end and a nut.
Start turning the nut or the bolt and old the other end with a ratchet and or Vice-Grip.
Keep turning until the mount and bushing are all the way down, remove the nut, and washer, replace with the socket, add the washer and nut and finish tightening until the bush is fully through.
Greasing the bolt really helps, similar to replacing the front wheel bearings on the car.
Briano1234 said
You need 2 large fender washers that are larger than the bushing.
Yep did that and didn't work, the bush just squashed versus sliding in.
Same way I get bearings to sit in too.
Be very careful not to poke a hole in the bush when pushing the edge into the mount hole.
mark1gls said
You may need to have it locked into a vice and use a pry bar or large blunt flat head screw driver to push the end of the bush into the mount hole when it's just starting to get squashed by the threaded bar and big washer.
I agree, probably not help with them been stiffer bushes.
Last edit: by abfmk1
abfmk1 said
From memory the metal bush is removed from the polly first or you,ll never get it in, think they are bonded in the rubber ones but thats much more flexible..
abfmk1 said
Here is one i fitted a few years ago.
That explains the difficulty… Way to clarify.
I can't remember where mine where from (I bought and fitted them when I first started my project back in the dawn of time!) but they were 2 piece so dead easy to fit!
paceman said
Is there not a metal insert in the bush? I can't work out in my head how the bush is just getting squished if it has the metal insert in it.
I've not tried with the metal insert in as that wouldn't allow it to compact.
Got them in in the end.
