location and directions to edition 38
(In Topic #81384)
Re: location and directions to edition 38
james28 said
can anyone tell me exactly where this is as northhampton is a big place :dontknow: ,… i am coming from the midlands . cheers from
Try this link:
http://www.edition38.c…index.php?showtopic=55858
james28 said
:dontknow: nothing is coming up on link apart from edition38 log in
I guess you'd need to register on their forum to see stuff. Anyway, here it is copied over:
If you click here you will pull up a map of where the show entrance is.
There is however, no way to pull back directions to this location, as it has no postcode, so we will be using the postcode 'NN6 0RH' which is for the house on the very corner of the showfield. Using this postcode in conjunction with your favourite routefinder (for example www.multimap.com), you will be able to find directions to the showground.
This postcode will take you within yards of the entrance, and the stream of cars should probably tell you where to go.
As a guideline, in case you dont know, if you're coming from the east or west, you want the a43.
If you're coming from the South or North, you want the m1, junction 15 (which will take you to the a43).
