yet another 20vt conversion thread
(In Topic #137149)
Now my first question is from what ive read i need the 1.8 mounts from a mk1 for 3 of the 4, except the cambelt end? Is that correct? (i know i need a custom jobby for the cambelt end). im hoping to use the box from the mk4 so will the mk1 1.8 mounts mate up to that? or again do i need custom ones?
Next thing is from what ive read i need 100mm driveshafts to work with the 02j box? now what car do i get these from? im guessing the mk1 shafts i currently have are no good, but what about the cv's? again some guidance from someone whose done it would be nice
Last question for today, the o2j in the mk4 uses a hydro clutch and id really like to keep this for relaibiltiy and day to day practicality( plus the girlfriend will be insured on this and her clutch control isnt great at the best of times, never mind with a heavy clutch). So what bits did you use to run a hydraulic clutch in the mk1? (i made a conversion to go the other way in a mini and change over to a cable when it had a vauxhall engine in it and tbh it wasnt great)
thanks in advance im sure il have more questions
mat
You can get 100mm drive shafts from cabbys, i brought mine brand new of ebay came with inner and outer cvs attached about £170, you then need to check how big the flanges are on the gearbox some have 100mm ones fitted mine were 108mm so had to change them.
As for the clutch i have converted mine to cable just for the ease of it and dont find it to be that heavy, i will be lookin into changin it to hydro in the future but makin my own conversion, you can buy pedal boxes that have been converted but they aint cheap so guess it comes down to money. Hope this helps Andy
And for driveshafts im probably going to be best buying some brand new ones then so im guessing the likes of gsf or similar?
thanks again
mat
http://www.ebay.co.uk/itm/RARE-MK1-GOLF-100MM-CONVERSION-DRIVESHAFTS-1-8T-VR6-16V-/170552253434?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27b5b4dbfa
mat
These are the same ones i got for mine, didnt change the hubs tho just ground the lip down on the outer cv jointRaul said
I got my shafts here, although I also needed to get 100mm Hubs to get these to mate up.
MK1 Golf 4x4 Build
MK1 Golf 4X4 | Facebook
Im not sure if your mount will be right as from what i remember it sits at a slight different angle dont quote me on that i maybe wrong but when i had my 1.1 converted to a 1.6 i had to have a mount of a car with the big block mount. Best thing to do is have a look at a big block car a physical look and do some measurements caus its crutial the the engine sits right.simongolf83 said
I'm also doing this conversion and I've had my mount moved back to the big block pistion but reading your post I'm s bit worried that my mount won't be right as it was the 1.1 mount is this right.
mat
Mat
