Will They Fit . . .
(In Topic #87358)
Will They Fit . . .
The kind chap selling them has said that the stud fitment is 100 x 4 ET24
Will they fit on my mk1 clipper ???
I look forward to your response
If there from a E30 you'll be fine, the slightly different ET is better for the golf believe it or not!
mk1 1.1 C
Only option is to roll the arches which should give you the clearance you need, or, not go too low, but put rock hard shock such as Koni Top Adjustables on to limit the suspension travel.
You will probably need both as the rear end on a cabby seems to suffer more than the old tin top!
My Build Thread
no ones discussed rubber here either, for instance stretched rubber would buy you a couple of MM's clearance on the inners & outers etc
35 or 40 profile rubber would buy you a few inches in the radius etc…
I have a lowered car with 205/40/17's on it with no rubbing problems at all 8O
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
My brothers old Mk1 had 15x7 et 25 MIM's off a BMW on it and the buggers stuck out plenty! Stretched rubber might help a bit, but it is not a deffinate fix as it depends on exactly what size rubber you go for.
My Build Thread
jamiegolf said
my 17's are the right ET for the car as far as i know
Which is…???
If you have 17's at ET 35 to 38 (Correct for the car on standard wheels) then you risk the inside of the tyre touching the spring platform.
The "Right" offset can change for any given size of wheel.
I'm just trying to point out that fitting a set of wheels to your car is not as straight forward as some people might think, especially if not standard size.
My Build Thread
et 24 on 7x15 with 195/50 or 45 or 40 will end in tyre contact with standard arches.
Sorry for not getting back sooner.
Got a little more info for you though . . .
Wheels are from BMW E30, size = 15" 7J ET24 4x100
Tyres are Yokohoma A539 tyres size = 205/55/15
Does this help ?!!
Ps, My clipper is as standard, no mods, not lowered etc . . .
With this setup, you will need to do some arch work, the wheels will fit fine though.
Still i would advise getting your suspension sorted first.
