Ill get an exact profile degree/duration for you asap . im running a tsr donnignton bottom end ( 1.9) ported and polished head with stainless valves , supersprint 4 branch , mk2 throttle body ( isnt it fun drilling and filing the hell out of the inlet ) and a very lumpy cam . i know my cam is a tsr one but ill have to find out the profile for you . where are you because i can get race power to custom make you one for exactly what you want . the only thing that you have to be care full of is using a cam with such a high profile/lift is that it would contact on a standard head , the head needs reliving around the buckets for the cam lobes to rotate properly , but with a cam of this size you would need to convert to and older solid lifter head . ( non hydraulic that is ) n e way i got 142.8 @ wheels , i also had the box rebuilt with a 1.6 close ratio gear set !! it does rip , gearbox rebuild is a must have ?280 @ kent transmissions , stainless 4 branch ?260 thru rimstyle ( speak to gary ) . Im going to be annoying now and tell you that i got it all ( the block + head ) off ebay for ? 150 !! if i can be any more help in any way please do ask .
