which 2.0 for my mk1?
(In Topic #128674)
searched the forum and i cant find a definate answer
iv got a mk1 5door gl looking to put a 2.0 8v in.
iv currently got a high lift cam, 4 branch exhaust, and bike carbs for a mk1 1.8 gti engine and a 2y gearbox.
if seen people use mk3 gti engines, are they a 'tall block' would my 4 branch fit this ok?
do i have to use the mk3 alternator etc?
which engine code is best to go for, im currently looking to get the ABK from audi 80 is this the only short block available?
sorry if i'v confused you
thanks for help in advance.
Audi abk is a tall block, fitted one many years ago
looks like i'll be better off fitting a mk3 gti lump
the 3a block is short 2.0 8v, but very rare now! some 4 branches wont fit the tall block, just fit an oem mk1/cabby/rocco gti 6 bolt manifold/downpipe
thanks mate,
do you know which cars had the 3a fitted?
Just fit a more modern, more readily available tall block, dosnt cause any problems that are not relatively easy to overcome.
earlier audis had the 3a, which is why its quite uncommon now. as above just fit a tall block, and choose your exhaust carefully. personally I've had nothing but wailing and knashing of teeth from 4 branches, never fit right. oem all the way, they flow just fine
3as are found in Audi 80s, around 1990
they're all the same really. the 2e code lump is better for digi applications but only becasue the dizzy will work with it. with k-jet/carb the dizzy will need changing no matter which block you get. preferable engines would be low milers or those out of automatic passats owned by old men
bits Id replace are all the plastic flanges (fit MK1 metal items where possible) rocker cover seal, all belts + tensioner. thats about it really! if you plan to run the mk3 managment replace ecu temp sensor and lambda probe, if going with a later engine then replace the crank sensor too
If you use k-jet, can you use the crank sensor..?? I was planning on just making a plug for that hole.. If, were should the crank sensor connect?
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
no use for a crank sensor on k-jet. just chop the wire off and leave the sensor in the hole to block it off
