which 2.0 for my mk1?
(In Topic #128674)
iv got a mk1 5door gl looking to put a 2.0 8v in.
iv currently got a high lift cam, 4 branch exhaust, and bike carbs for a mk1 1.8 gti engine and a 2y gearbox.
if seen people use mk3 gti engines, are they a 'tall block' would my 4 branch fit this ok?
do i have to use the mk3 alternator etc?
which engine code is best to go for, im currently looking to get the ABK from audi 80 is this the only short block available?
sorry if i'v confused you
thanks for help in advance.
do you know which cars had the 3a fitted?
bits Id replace are all the plastic flanges (fit MK1 metal items where possible) rocker cover seal, all belts + tensioner. thats about it really! if you plan to run the mk3 managment replace ecu temp sensor and lambda probe, if going with a later engine then replace the crank sensor too
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
