Wheel wobble severly
(In Topic #113342)
Please help i feel defeated
I've gone over the nuts and bolts but still no joy
When you say ALL suspension components - can you list what you're replaced?
top mounts
struts
springs
anti roll bar bushes (altho using exhaust clamp to clamp outter bush to wishbone)
wishbones
bushes (urethane kit)
balljoints
tie rods and arms
i think thats all…
I am thinking wondering if i've put all the washers back on and done all the nuts up tight enough. I've jacked the car and wobbled the wheel by hand and i'm sure the whole hubs moving. Its raining and stormy so its nasty trying to look at the mo lol
Its just weird how its both sides too to me
If the wheel is off and the hub carrier is wobbling, then you'll need to look at where the movement is. I don't suppose you held each piece (bolt, bush, component etc) side-by-side with the old and new, while you replaced them, to check they were the right size etc? Everything torqued down to manufacturer's recommended torque value? Did you replace/fit the small cylindrical metal spacer in the top mount too?
i know i havn't put wshers on the lower bolt thru the strut to hub and no washers on bolt securing balljoint to hub.
i can't be sure becuse i have dark cloud cover and can't see to well with the constant rain but i think its the balljoint, arm or bush maybe.
i did check sizes roughly tho so i think thats cool.
p.s. crazyquiff does new anti roll bar wishbone clamps
wobble
dan
here for a good time, not a long time
and thanks for the link for crazyquiffs doing anti roll bar mounts. I'll get me some
i think my driveshaft nuts are all good tho as i can't seem to be able to turn the nut either way even tho i'm using a hench breaker bar….
rubjonny said
I had heard that moving a car with loose driveshaft bolts can cause the bearings to be destroyed, so i guess it came down to that.
Humm I noticed that the wheels/hub on my cabby where wobbly but I had no drive shafts. I've been rolling it around a bit on them with out any shafts (Probably no more than 200mts total). I'm currently fitting the driveshalfs as I think this will solve the issue but I hope I haven damaged the bearings as there all new.
I would check that the hubnuts done up correctly and the ball joints.
James
1987 Golf Mk1 GTI 1.8 Cabrio
take care people and thanks once again
