What's the largest & most modern small block that will f
(In Topic #84052)
Doing some research into the cheapest way to make a quick small block engine, and I'd like to start with an engine which has the lowest mileage and greatest capacity available.
I'm thinking of running it on carbs, so a modern ECU won't be an issue.
Any opinions would be very welcome…
Rich
1983 1100 C
1983 1100 C
Should I be looking in the scrappy for a 1.6 out of a Mk3, or did they continue it into the Mk4 Polo too?
Rich
But an all alloy 1.6 would be very cool indeed… I've had a brief look on Club Polo for info on small block engines, but are there any other sites you would also recommend?
Thanks in advance
Rich
anyway i asked about the 1.6 16v before and the club lupo guys reckon its the same mounts as the small engined mk1 golfs etc.
The drivers side mount will fit straight on but only two bolts line up, u can run it fine with these two as some people do or modify your mount to fit correctly.
If your get a 16v with the small rocker cover and coil packs to save money and on custom ignition i believe on the end of the inlet cam there is a drive, flick the blanking plug out the head and a hydro head'd polo distributor will fit
I was going to fit a 1.4/6 16v out of a lupo into my mk1 using the above and also a set of bike carbs meaning it would be alot cheaper to build. i have now gone down the polo gt route 5sp box and bike carbs but if i ever find a cheap lupo gti engine i wouldnt mind throwing that in
Chris
Don't suppose you know whether any VW 8v hydraulic heads would fit the small 1.6 block? I'm not convinced a 1.6 is big enough to warrant 16 valves, especially as I prefer low-end grunt to high-end power.
Rich
Thanks for your help guys
Rich
