what do you guys think of...
(In Topic #85635)
changing a 1.6 (pierburg) carb engine to a 1.8 (weber) carb engine? Primarily, I'd like to change my carb for a webber, but if I could find a working 1.8 engine while I was at it that had a weber attached?
Would a mk2 1.8 driver engine be directly swappable with my 1.6?
Any advice muchly appreciated
1984 GL cabriolet, 1.6 carb (EW?)
Cheers!
Cheers!
1984 Mk1 GL Cabriolet, black.
same as mine. 1.6GL EW. sure a mk2 1.8 GTI engine will go in no probs. Block off the injector holes, bolt up your manifolds, and add a weber 32/34. easy!
I was going to do this sometime soon. Just need a very good bottom end to find, already got a good head.
another way is too just change the pistons/crank and rods. Which will keep the original block and then that would give you a 1.8. Keeping your engine number. homing out the bores add new rings and way your off.
already have weber 32/34 on my EW, which works ten times better than the horrible pierburg..lol…which i would re-jet for the 1.8.
if you can find a decent 1.8 motor, then why not.
Yep and it shouldn't be too difficult or technical either. There's far less connections to worry about, and more space - no oil cooler, smaller radiator, smaller airbox, etc etc.
Awesome, that souds like a plan. At least that way I dont have to worry too much about taking my pierburg to bits
satelliteone: I've got a mk2 gti engine in bits in me garage that I was thinking of refurbing, but tbh I could do with the space at the moment. If you want all the bits to refurb/rebuild the block super-cheap let me know. can email u pics if you like.
i would love the block, just that im saving for a new roof at the mo, trying to get some cash togther for that, once thats done, next step is the engine..
hi satelliteone, i'm trying to sort out a 1.8 engine now with weber carb. If/when I sort this out you would be welcome to the 1.8 gti block and bits gratis, all you'd need to pay for would be a courier. I'll be needing the gareg space!
yeah sure thanks, thats really good of you. let me know when, i will see what i can sort this end for collection... ur a star
lucky andy…
