what do i need list please!!
(In Topic #101788)
Which are best!!!
List so far
Manifold
Twin carbs
New gaskets
Fuel regulator
I am doing it so it tidys up the engine bay also, i dont like have the pipes and cables from the injection system of the gti, going to get changed to a s3 anyway but this is for the mean time,
Any one selling a set up for the mk 1 gti?
Also what do i do about the injectors in the head do they need blocking up or run a different head etc if so which one cheers steve
abfmk1 said
Think youll need to dump gti fuel pump for something with much lower pressure even with the regulator.
Why?
abfmk1 said
Because the gti pump runs at about 5 bar, what do carbs need 5 psi?. dont think the regulator can cope with that difference but i may be wrong.
The GTI pump will happily 'pump' at 0.1 psi if you want it to. The pump pumps, the pressure it pumps at isn't set by the pump itself but by the restriction upstream. Basically, a restriction occurs and it can keep pumping at higher and higher pressures (in fact, I've seen K-Jet fuel pumps pumping at around 8 bar) but this doesn't mean it can't pump at low pressures - quite the opposite.
In fact, from the pump's point of view, it will be like its on its holidays, pumping 5psi or whatever you need for carbs.
wooders said
ob a standard 1.6/1.8 8v engine? i really wouldn't bother
Yeah. Speak to grungeisdead about it…..
surely the heat from the exhasut isnt going to help
get the s3 lump in there job done
112 bhp + 28 internet horsepower = 140 bhp engine
do they really produce that much bhp??
Carbs have their downsides, frequent visits for tuning, even more frequent visits to the petrol station, but great noise and they look the bollocks!!!
BTW the engine had been fully rebuilt (lightened and balanced) with fancy cams, head and matched / ported inlet manifold. Along with a custom exhaust it made 138 horses, until some numpty pulled straight out in front of me, when i was crusing at 40!!!!
Great car, expensive to do the work, probable cheaper to fit throttle bodies with a custom ecu (hear great things about megasquirt) more reliable, economical etc etc.
Tim.
steven_c said
just want to do wont be buying brand new, justs that i will collect.. back to the list please
In fairness, there's been some reasonable questions asked:
- Why won't it run on fuel injection?
- Why would you fit them to a non cross flow head?
- What about heatsoak from the exhaust?
The injection system will work but i dont like it, so its going,
Why would you fit them to a non cross flow head? (what do you mean by this change the head to a carb'd head.. ?
