What breaks?
(In Topic #75601)
What breaks?
I've heard of two way to do a budget (ish) break swap. and am wondering which is more recomended:-
sky rocket 16v calipperes and carriers
or
280mm disks
with the latter could any one give me some more info on doing it
or
280mm disks
Mk1 Big Brake Upgrade
http://www.clubgti.com…_posts.asp?TID=62598&PN=1
I wouldn't consider using the 280mm upgrade because if you've seen the size of the Mk1 GTI pads (the kit's that are avaliable to upgrade a Mk1 to 280mm discs use Mk1 GTI calipers) you're not gaining any more surface area other than maybe a small amount of extra leverage if the 239 pads are positioned to the edge of the 280mm discs but still, the pad size of Mk2 pads is a big improvement and cheap if you can find the correct caliper carriers.
