What are these wires for?
(In Topic #139357)
very new to this forum malarkey so ill just get straight to it.
i currently own a mk1 clipper convertible 1.8 8v with a weber carb (EX engine i think)
at the moment i am in the process of stripping it down for a 1.8t swap
my query is what is each wire that goes into the engine for, so i can label them up prior to taking the engine out.
(i.e which is oil pressure sensor, oil temp sensor etc.)
a diagram would be ridiculously helpful.
when it comes to electrics you could get more knowledge from a dead babies arse.
any help would be spot on…
i think it would be easier if i took a photo of each plug and then maybe people on here could tell me what it is. ive looked for hours for an engine wiring diagram for my car but theres nowt out there
btw i followed your build v.closely epic stuff
once the loom is out strip it down completly then use the wiring diagrams in the haynes and the fusebox faq to go thru all your fusebox pins till you have identified the ones you need. worst case take a pic of what you arnt sure of and we can id them for you
i know 1 is thermo time switch, another is coolant temp sensor. just not sure which is the last one and which plug is which as the colours of my wires dont match the service manual.
like i said, ignore what you have in the bay. use the diagrams and the fusebox sticky to identify the pins on your fusebox plug, then work back from that! pretty much all the engien bay stuff on the engine loom isnt even needed when you go 1.8t swap
but either way, forget the engien side start at the fusebox side
now thanks to rubjonny its all labelled up to (just in case, im a dunce when it comes to electrics.)
i was also hoping rubjonny would be able to knock up a loom for either an emerald or megasquirt ecu.(which is best?) what i need to send to you? im guessing my loom from fusebox onwards,mk 4 loom from ecu to engine and relevant ecu loom (do you need lighting loom?)
cheers for your help im glad i signed up.
just buy my whole car job done 20vt conversion complete lol
and plus i think it would be good experience to do it myself. however…. if your willing to break it then youve got a buyer for the engine and box.
mk4 based looms are £100, but i have 14 to do so dont expect it to be done before feb! or just buy a ready made one, saves lots of hassle
where can i get ready made looms from or is it just a case of trying my luck on fleabay?
bit off topic here but as my cabby is an 89 carb model do i need to change fuel pump, fuel lifter etc, the fuel lines are already on the drivers side.
for the fuellign you'll need a mk1 gti fuel pump, fuel lines you can make up with fuel injection hose as its not going to be under as much pressure as it would if you went k-jet. you dont need the fuel accumulator but you will need a luift pump and under-car reservoir from a late spec cabby/scirocco injection or g40 shape polo. you might find mk2/3 or polo plastic fuel lines fit nicely too
would these be ok?
http://www.ebay.co.uk/itm/MK1-GOLF-GTI-PASSAT-SCIROCCO-GTX-FUEL-INJECTION-PUMP-/150710414846?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item23170a6dfe#ht_3174wt_952
http://www.ebay.co.uk/itm/VW-Golf-1-8-GTi-MK1-MK2-1982-1992-New-In-Tank-Fuel-Pump-/180737981779?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a14d2bd53#ht_2725wt_1185
with regards to the accumulator and under car reservior dont they do the same thing?why dont i need the accumulator? wheres the best place to get a reservoir from (scrappy?) and finally i thought k-jet were the best pumps for this kind of thing.
cheers for your help so far im finally getting to grips with 90% of this conversion now.
for the main pump buy something like this:
http://www.ebay.co.uk/itm/12MM-BANJO-8MM-HOSE-M12x1-5-BOLT-FUEL-OIL-/390330527114
then you can use normal push fit fuel injection hose
