Ultimate brake setup
(In Topic #96490)
all bolts on from the stub axle onwards…
and a set of scirocco hand brake cables for the length.
93' cab in need of a miracle
mk1nath said
rear disks from a mk2 gti would be a big improvement
my own view is that rear discs dont help they will make the car back happy under breaking the mk1 rear drums are fine just upgrade the fronts to the bigger discs and calipers from and early audi 80 :wink:
you could go stock calipers spaced out to take 270 or even 285mm dicsc,
or theres mk3 calipers from gtis up to 95-96 which gives 280mm discs when using G60 discs and a larger pistion, these need a adaptor bracket too. this is the set up im fitting to my mk1 gti track car.
or you could go 4pot with will wood calipers etc, good but costly, and then you also have to use thier pads too, something to take into account.
you also need to look at running a larger master cylinder and poss servo too. like I say it all depends on your budget and what you want from it
a waste of time imho, the back dont do that much, drums if looked after, cleaned and checked work brill and the hand brake is better, i just use the stock drums on my track car its fine.
Website Manager
IMO rear disks are a great mod, self adjusting drums are just a pain in the rear, and require lots of tlc to keep in top order. In the 4 years since I fitted my disks I have not had to touch them, the pedal height stays the same and they look sooooooo much better.
I have not experienced any back snappy braking even under really hard braking.
On the front I have the 256mm setup from a 16v mk2 using the Audi 80 adaptors. I have combined them with a 16v servo and 22mm master cylinder and goodridge hoses and copper nickel brake lines. I also replaced the rear compensator to give a really clean system.
Do be careful with going too big on the front disks, you can overbrake a car, the mk1 is very light.
hmmmm
brakes
16V Servo, 16 M/C.
Vauxhall Calipers/Mk2 256mm Discs Up front
Mk4 Golf Rear Calipers/Mk2 Disc set up on the rear.
I would never bother changing to rear discs if my car didn't already have them when I bought it, does feel slightly overbraked to the rear.
2 1983 Campains (concours & track)
1985 Blue GTi Ragtop
2001 Bora Estate TDi SE (very very rare)
2000 Golf TDI commuter
2005 T5 Transporter with 394000 miles on it!
fine for me thats with about 160hp
g40'd ratter
<div><embed type="application/x-shockwave-flash" wmode="transparent" src="http://w139.photobucket.com/pbwidget.swf?pbwurl=http://w139.photobucket.com/albums/q312/Forgeman/75e604af.pbw" height="120"
could anyone tell me whether putting on both teh 16v servo and 22mm matercylinder would be a straight swap with the stock components, or is there some other tweking that has to be done too?
much appreciated,
simone
Its not a straight swap there's a little tweaking needed see here:
http://www.vwgolfmk1.o…ontent&pa=showpage&pid=40
James
1987 Golf Mk1 GTI 1.8 Cabrio
