twin 45's on a gti
(In Topic #91610)
twin 45's on a gti
if u need to no any think specific mail me by all means
ive only got 1 problem and thats that the top water pipe is stuck between the carbs
i will look for it
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
u need the inlet manifold, two carbs (idealy a matching pair) linkage kit, choke cable for cold start and i would advise in getting a new throttle cable. also dont forget to get a new inlet manofold gasket, and four socks (airfilters)
twin webbers are abit of a pain to get set up running perfect and a few people reckon that dellortos are much better as they dont need setting up as often as the webbers, i would advisew you get a fuel regulator witha built in gauge as these carbs dont want to be no more then 3psi? of the top of my head and the regulater must have a fuel return port to allow for the excess fuel to return back. (so it should have 3 fuel lines coming of it, fuel feed fuel return and fuel supply to carbs)
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
turkish said
hey soz my computer went dwn all sorted now, can i use a gti fuel pump to run twin 40's? :dontknow:
No - Pressure is way too high…
As said above, you only need 3 to 5 PSI, so would need a Pacet pump or similar with a regulator to control the flow.
My Build Thread
