twin 40s onto mk1 driver
(In Topic #84007)
how much will it cost? is it more reliable than usual carb?
and how often do they need adjusting?
i wouldn't advise using the standard g40 cam. forcely induced lumps tend to run milder cams than thier normally perspirated vehicles
what else would you recommend?
whats needed for this, manifold, twin 40 carbs, or could i use bike carbs, how easy would the fuelling be to adjust.
if i do keep the mk1 i would want to make it a bit more powerful and a bit more reliable as it will be used everyday if i keep it
Turbodiesel?
Big block carb petrol?
Regards Volkswarren
'86 caddy on carbs
'79 mk1 project
'79 mk1 project
if i do keep the mk1 i was looking at options to do to the original engine to make it more reliable but give it a bit more uumph!
so an engine conversion is out of the question for now unless its a straight swap job on same mounts, wiring etc. was thinking of polo gt engine maybe, could i use the 4 speed box on this or would it have to be the 5 speed one
I am guessing, you are looking for inexpensive tuning options?
G40chris said
if so im looking at around ?250-300
What car's it going into, and does it already have any braking and suspension mods?
I'm not sure on this one, but I think the 1.1, 1.3, 1.5 and 1.6 carb models all had the same brakes and similar suspension, so you'd be okay here but to go any higher than 75bhp (the 1.6 carb) you'd need to consider an upgrade to GTI items.
You can forget about fuel injection, there's so much to modify on the fuel system you'd soon have used all your money up.
Best bet would probably be 1.8 carb engine from a later Clipper, or something like that. You could chisel off your existing engine mount (carefully), do all the prep work and get a garage to weld it into the right position for a big block, for not-too-much. Then you'd simply need to purchase:
1.8 carb engine and box, and all its gear linkage I think?
1.6 manifold and exhaust system for hatchback
possibly a few other bits and bobs
There's plenty of info around, concerning swapping small block to big block engine.
Amazingly they managed to push 1272cc to produce 170 bhp with a few other odds n sodds. Which gives me some hope lol
Ebo
1.3 Driver - 1.8t in progress
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=56551
Daily driver : e36 325 tdi se / slammed on konis and bbs rco401's
Daily offroader : discovery 1 6" lift monster
