twin 40s on a 1.8gti
(In Topic #84765)
also is there anyway of blocking up my injector ports without making the head only being able to run carbs?
Rob
You can block the injector ports with a self made blanking plug an O ring and the original injector inserts that screw in to trap the blank behind it.
I actually used 4 1 penny pieces as a test on a 1.8 running carbs a few years back and it worked fine.
The guys at the head reconditioners laughed their heads of when they saw it though.
Mk1Fey said
cheers for the tip, and do u know where i can get the different swan manifold from?
Don't think you can get them… Would be a custom made affair I think.
Do you mean that you want the manifold to loop back over the top of the rocker so that the carbs are pointing forwards?
My Build Thread
ye i want the carbs to sit just above the rocker facing the front of the car, any ideas where i would get a manifold from?
Never ever seen a manifold like this. I think it would have to be custom made and probably not worth the effort or expense…
My Build Thread
16v items sit on the front of the engine because the head is a different design.
I guess if you fitted an American Market cross flow head but then you'd have to do work on the block too.
You could get a pair of down draft carbs like Dellorto DRLA's but then you are looking at a custom manifold fabrication.
If you wanted you could get really long ram pipes that bend up and over the rocker cover. Remember - the longer the ram pipes, the better but also bear in mind you want cool air getting inducted.
Gearbox oil fill plugs are ideal for blocking up the injector ports.
I've personally had better performance from twin 40's than K-jet fueling but they have to be setup properly.
