Turbo technics
(In Topic #74747)
Turbo technics
NO1. is complete with rebuilt engine and recon turbo.
NO.2 less engine and turbo :dontknow:
I can get the engine and kit for ?500 but no bills for work done so i cant say the engine has been rebuilt, i am just going from what he has said.
How reliable is the kit and how easy to fit? will my gearbox handle the power? :dontknow:
Realibility. good if they are put together properly, and you set-em up wit the right fuelling, get it wrong and liekeany Turbo car they go bang big stylleee (been there a few times and it hurts the pocket ).
Gearbox - the big debate - some will say that you need to change the box as they will not last, but I run a normal 1.8GTI box and so far its never been a problem. (195K and no gearbox/diff, CV probs as yet), so imo a good box wil last, but like most things a dicky diff pin and its all over so its really luck of the draw I think.
Oh, and if you don;t want the part kit, point 'em in my direction as I'm always looking out for spares for mine as they are a "little" hard to come by :wink:
Mk1 Lahsa green, BBS RM, Mk1 Silver Campaign, Mk5 GT TDi, Audi A4 Avant S Line
also what turbo was used ?
cheers for the help
stuart
www.msportcam.co.uk
take a look at our website :www.vwturbo.co.uk as there is some detail of the conversion on there, and if you need anyhting else let me know.
In essence, it was standard rods, standard inlet manifold with adaptor unit, and if it was a 1.8GTI machines pistons to lower compression. Some other bits n bobs as well which I can fill you in on if you need more info. :wink:
is there anyway you could email me a large picture of your engine bay so i can see how they did the conversion ?
if the manifold i have will do the job then i will be looking at using a megasquirt ecu to control fuel and ignition i may also need to get another turbo as the one i have might just not be big enough.
it'll be done to a 1600Gti too
if there's any dtails of the conversion you could tell me that would be great !
cheers stuart
www.msportcam.co.uk
is there any chance on some of that info for me ?
thanks in advance
stuart
www.msportcam.co.uk
