Trying to replace engine mounts
(In Topic #133763)
Ive got a 9a engine with an 02a gearbox, but the engine mounts seem worn as there seems to be a fair bit of movement in the engine when you blip the throttle, the exhaust also moves a bit under acceleration.
What mounts would I need to do in the engine bay? and does anyone know where I could get a full set?
\'83 9a transplant
It is the forward and back flex i have a problem with. I got a new exhaust fitted recently and the flex isnt doing much for the connection from the manifold to the system, so im playing it safe as i dont want to shell out for repairs on a brand new exhaust
Edit - I guess standard mk1 'big block' mounts will fit correctly?
\'83 9a transplant
I'm in the same boat at presnt, my rear mount is about as rigid as a loaf of bread, not sure if go diesel mount or prothane as yet. certainly not driving the car until it's sorted.
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
on my mk1 i used the poly front, diesel rear and just used the best old side ones i had in my bits box, no inserts and no replacements. coped with my kr engine just fine
