strut brace
(In Topic #83053)
Guest user
strut brace
Jack up both sides of the car at the front so you can get underneath, undo the front wishbone bolts on both sides, slide the strut brace over the holes, and adjust the length to match the holes exactly (if it comes with a rose joint type things on each end).
Once you're happy, use the longer bolts to do it all up again. Think the required torque is around 100Nm, but definitely double check that in the Haynes manual.
It's a really easy job provided you have 2 axle stands, a torque wrench, and possibly a breaker bar depending on how tight the existing wishbone bolts are. Took me about 30 mins in total…
HTH
Rich
What happens if the strut brace does not come with the rose joint type things to adjust the length? Are these a bit of a nightmare to fit if it is a non-adjustable brace? :starwars:
Thanks!
1983 Lhasa Green GTI
Benici said
Can I ask a related question please? I'm thinking of fitting strut braces also.
Thanks!
One end normally has an elongated hole to account for any small differences between the chassis tolerances of different cars. If this doesn't fit, your car is probably bent!
My Build Thread
its an eibach lower front strut brace…
K-bar mounting points. Requires drilling the chassis for the two rear mounts (slotted for dimensional variations).
Photos of my Cabriolet's K-bar installation:
Subframe installation - uses control arm mounting points.
cheers! 8)
…as I will need be the boot space.
…make that "as I will be needing the boot space". ops:
