stripping a MK1 down
(In Topic #94647)
i m new on here and was just wondering,
what does a typical MK1 wiegh ? whats the lightest i could strip it down to ?, does anyone know of any really light wieght ones ? i know HR engineering do carbon pannels etc but does anyone else do light wieght bodywork for the MK1
much apriciated
Finlay
Finlay
Finlay
hello!
I've read about a guy who got one down to 660kg, but he took a holesaw to almost every inner panel, replaced the glass with lightweight stuff, and completely gutted the interior.
There's a thread about it on No-Rice which is a great read (apart from the ending)
HTH
Rich
Under dash tray
Rear seats
Carpet and underlay
Door trim panels
Other trim panels (eg seatbelt covers, parcel shelf supports, etc)
Passenger seat
Seat belts (except driver's)
Rear bumper
Headlining
(All the above is free)
Front bumper (relocate indicators somewhere else, costs money)
Scrape sound deadening material off inside of floor
Scrape underseal off outside of floor, wheelarches
Plexiglass (except front screen)
Ultra light alloys
Ultra light calipers
Carbon fibre hatchback, doors, bonnet, front wings
Carbon fibre driveshafts
No battery or alternator (or race versions)
No oil cooler
No cooling system
I did the first 8 on the list I can tell you, it works!
I've also seen that the mounts for the seat belts have heavy plate behind them, obviously you'll need to leave a few in for yourself plus passanger if your having one.
Where can you get the poly windows from? and do they have to be made from a certain standard of material?
Danny
1983 1500 GL Resto
2003 Leon Cupra
2003 Leon Cupra
so far bumpers have gone (front indicators are flush mount side repeaters in the holes where the wiring used to go, grand price of ?10 from chav world (motorworld)) rear bumpers have gone, lower dash has gone along with gear suround, rear seats gone, all trims gone (or going…door card are still in for now but need to come off to remove speakers) carpets are gone, rear wash wipe is gone (that saved about 3kg alone!)
you can then look at things like tubular manifolds as these are lighetr than the cast ones and improve the poke, i have just had my middle box removed when i fitted the new manifold as this allowed easier fitment and also saved a couple kilos more.
plastic windows save some good wieght too, a rear one alone saves about 4-6kg, but becareful on the side fronts as they will scratch esp if they are wound up and down.
a carbon fibre bonnet will save a shed load too, but then you are looking at big ? per kg, and tbh going on a diet would be cheaper…
also think of things like coil overs as these will reduce wieght and improve the handling, and the more wight you can save thats un sprung the better, as this will improve handling, hence why i am still using 239 discs and trying different pads to see if i can get a set up that is easily as good as monster brakes, as smaller discs = less wieght. so im now on the same zinerman drilled 239 discs, with mintex pads (i was on gfs stock pads but cooked them on track)
dannyk said
I'm stripping mine down just now too, have removed all the interior bar the dash and headlining, going to do those soo tho, i've also cut out the spare wheel well and will replace it with a sheet of metal.
Danny
hello Danny
i m out in westhill where abouts are you in town ?
as for windows, what i have done in the past is just buy sheets of poly and cut then to size using the original window as a template
Finlay
Finlay
Finlay
Didn't notice you where from the aberdeen area! :roll: i'm out at balmedie.
Been reading about the windows issue and the only one they check for the MOT is the windscreen aparently so it seems you can use anything for the rest!?!!
What thickness did you use, 4mm?
Danny
1983 1500 GL Resto
2003 Leon Cupra
2003 Leon Cupra
speak to pascall on club gti, he's who im ordering mine off when ive got the spare dosh as thats the last thing ive got to change thats good ? per kg saving
1983 1500 GL Resto
2003 Leon Cupra
2003 Leon Cupra
dannyk said
hi finlay,
Danny
i cant honestly remember, i tried different thicknesses, i think i ended up with 3mm poly ? as they seemed to be the best comprimise between stiffness and wieght
Finlay
Finlay
