stich welding.....yes or no
(In Topic #117256)
By all means seam weld areas between the axles but there's not really anything in between not doing it, or doing the entire shell, pillars and all, etc which would be time consuming! A weld-in cage + sills + weld in seat mounts and proper racing seats would be a reasonable addition of strength.
Vw did a better job, so just reinforce the engine mounts and fit a strut brace front and rear and it should be fine.
If you really wanted too you could weld a plate onto the strut top mount as a precaution but unless you plan on rallying it it should be fine standard.
Jon.
Have a gander on CGTI, it's a common mod for track guys.
