staggered ats classics question. 8j and 7j
hi there been offered a set of staggered ats classics for my teledials which are currently 6jx15 inch, the ats classics are 7j on the front with et 10 and 8j rears with et 0. they will fit on ok wont they? help much appreciated, cheers lewis :)
sproutsy
Im assuming 13"?
Tyre size and how low you are will be a factor on whether they will rub or not.
Also the fronts might poke out a bit.
And depending on the backs of the wheels you may need to do some caliper work. I did with my alleycats.
yeah 13s buddy, caliper work, i dont like the sound of that, im currently running bigger disks on the front atm and need to buy smaller discs and take the spacer off so i can fit smaller wheels, cheers , lewis
sproutsy
what do you mean caliper work buddy? im worried now... cheers, lewis
sproutsy
From the pics Ive seen of your setup you should be ok.
On the cabbys (and I believe later tintops?) the calipers are different and have a kind of strengthening bar on the side. This either needs cutting off or you need to run massive spacers or you need to swap calipers to the ones I believe you have so you should be ok!
But I have never seen classics in the flesh so it might not be a problem anyway. Im just basing this on what I had to do to fit my 13" alleycats.
phew, going to find out later wether they do fit over, fingers crossed they do or ill cry. cheers for your help buddy :)
sproutsy
