Springs MK1 Driver... Help!!!
(In Topic #75971)
I ordered a set of lowering springs to replace some worn ones (broken), and assumed mine were not the pigtailed type, wrong!!! (on the front)
So, do I get another set of springs or can i replace just the cups at the top of the front struts to accomodate the new springs (they are mk1 springs)????
And if so which MK1's had non-pigtailed springs? I should have checked when i ordered, but was told that very few mk1's had pigtailed springs on the front so I thought, oh well, I wont be the minority!!!! More fool me!!
So any help gained here is appreciated!!!
MK2 GTi 16v
I though all MK1 springs were the same shape…???
What the hell have you got if they don't fit?
My Build Thread
Anyone car to get artistic in Paint to show the difference?
Will
out of interest what springs are you trying to fit(make, lowering etc) i'm trying to find some for my driver, but the gti items are no good because 1.1,1.3's are so much lighter than gti's which means any lowering rate is lost and you end up with a car riding at the same height you started with.
Rusty Hookers Dub Club
Dan, the springs are Jamex I think, 60mm drop. I did order them for a DRIVER but knowing what suppliers are like they could well be meant for a GTI? They cost roughly ?55.
I will be taking a look in my haynes, (doh), should have done this earlier.
THe spax tems I took off never really lowered the car, being 18 at the time we just took a couple of coils out!!!!! Not too reccommended!
The ride height I hope will not alter too much as the car is running on 17's but I aim to get rid of these in favour of something a bit more suitable 15's and old skool maybe!!!
I will keep you posted on how things go.
Once again many thanks
Gav
MK2 GTi 16v
AL_Mk1 said
Pig tailed?
Pig tailed, the coils get smaller to the top of the spring!!!
Not pig tailed, all the coils of the spring are the same diameter.
Hope this helps.
MK2 GTi 16v
same here, i need 60mm drop and then i'm fitting porsche teledials!something a bit more suitable 15's and old skool maybe!!!
MK2 GTi 16v
