smooth engine bays..
(In Topic #117650)
wiring is hiden in the chassis rails and theheadlight wiring in the inner wing and up through the crossmember.
I have just done mine and it's a lot of work although if your running carbs like above there are only 5 or 6 wires to run to the engine.
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
i am partially doing mine at the moment. i am keeping my scuttle though as i want to retain a heater for inside the car.
paul_h said
you need a hydraulic pedal box to hide the brake line.
rightyo lol, out of curiosity (and cus im new to the vw scene) what cars can i get a hydraulic pedal box off?
Makes it easy as pie to service id think.
Overboost said
Looks like all the gubbins is missing.
But a nightmare to fix any wiring issues!
You can take the motor off smooth the scuttle and keep the matrix though so will still have warm air going onto the screen.
I'm going to run a heated front screen on mine at some point.
I don't really plan on using it when it's wet and cold though so doesn't really matter to me.
I have been cleaning up my engine bay a bit, fitted a top fill radiator and re located the coil. At present the wiring looms are going back to the original position as I have had enough of extending wiring for the time being.
I think the above look is only for show cars as there is no heater, an important item if you live in this country. Its a fantastic look but a massive amount of work.
I think the photo is of TUK custom's car, these guys are at the top of the tree at present, the (unfinished) 'rocco on display at E38 was as impressive, the paint must have cost a fortune and if far better than my car's bodywork! :roll:
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
just been looking at 12volt heaters on ebay, would 2 of these under the dash be sufficient if plumbed into the original pipes?? so that heat can be directed into cabin or at screen?? this would also do away with water pipes going into bulkhead.
http://cgi.ebay.co.uk/CAR-HEATER-HEATING-FAN-PLUGS-INTO-DASHBOARD-12v-12-VOLT_W0QQitemZ360121166603QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item53d8e4eb0b
I think it's one or the other, heat or a totally smooth bay. My car will always retain the factory heating and for that matter the rain tray and associated bits as I want the car to retain some of it's originality and practicality.
It's all a matter of taste, budget and skill with smoothing the bay. I may well now be re routing some of the wires this year as I have finally got the arch liners out of my car so I can get to the inner wings now!
a car is not cool if you can only use it on sunny days (in my opinion)
i am doing this car to enjoy using not, pushing it off a trailer at shows is not my bag, but i am always impressed by the cars at shows!!!
