slight brake binding issue. Any ideas people?
(In Topic #97006)
The problem: After car warms up, cars passenger brake begins to make funny noises and vibrations when pulling off. If i press the brake slightly noise goes away, but it continues to get worse.
What ive tried: Adjusted brake linkage bar, so at least pedal is in alignment with clutch pedal. Brake servo pin seems fully out. return spring where it should be. Checked brake line for any kinks, no problems there. I cleaned up and greased slider bolts on caliper.
Suspicions. disk doesnt seem to be exactly in the centre of caliper carrier. Probably need to grind down carrier a bit more for perfect fitment. Just a mm a or 2 max. Maybe was better off using hubs off a 16v, are they a direct fit?
btw: does anybody know if the brake pipes have to follow any particular order going into master cylinder? I have 4 ports. put fronts on driver side, rears on passenger side. Could this cause a problem? Might also get a wire brush on angle grinder to make sure caliper isnt seizing when it expands due to the heat. I am using copper grease already before anyone asks
Golf Clipper 1.8 Carb F Reg in Blue
mods and work so far:
mk4 rear disk
vr6 calipers and g60 disks
9" servo and 16v master cylinder
h&R adapters and d90?s 6" front 8" rear
webber carb
inlet manifold, rocker cover & exhaust mani gaskets
mk4 rear disk
webber carb
82 golf cabrio (long term project)
83 golf driver (now a gti)
87 mk1 caddy
2004 landrover defender
2014 landrover defender
87 mk1 caddy
mk4 rear disk
webber carb
mk4 rear disk
webber carb
mk4 rear disk
webber carb
mk4 rear disk
webber carb
just2zang said
yeah cut it so i could fit the return spring back in, and wound it right down as far as it would go.
How much of the thread did you cut off?
mk4 rear disk
webber carb
mk4 rear disk
webber carb
just2zang said
basically enough to clear the return spring hole, and it turns out the clevis pin wound down as far as it would go on the servo
Did you measure it in mm, and compare with the existing (stock) servo you took off? I think there's a chance you've not taken enough off, since there was a myth going round for a long time that you need to chop off 5mm. In fact, when I measured and compared with stock, I needed to remove 10mm of thread; then the clevis pin was wound fully down.
mk4 rear disk
webber carb
mk4 rear disk
webber carb
http://www.vwgolfmk1.o…ms&file=viewtopic&t=13901
