sitting engine
(In Topic #81706)
sitting engine
then you can try it with gass, etc, clean up the dizzy or place a new cap on.You could do a pressure test too.
Be sure not to run it for to long as the cambelt may snap causing mucho dammage
So many dubs so little time, so much rust
The 1.8 is apparently a non interference design, meaning the the valves do not contact the pistons if the belt snaps…
Not sure if this applies to the 1.6.
Pour a little engine oil down the bores (Through the spark plug holes) and turn it over by hand a bit. this should help lube up the internals before attempting to fire it. It will smoke for a bit if you do this though.
The rings may be seized into the pistons meaning you will not get compression so it may be worth checking this first. This is most likely if any of the induction system has been removed allowing moisture into the engine.
My Build Thread
I replaced the following before I tried starting: -
Oil
Coolant
Spark plugs
HT leads
Dizzy cap
Rotor arm
I risked the cambelt it came with, but if you have the time I'd recommend you change this too, as others have said.
I'd also recommend you inspect the fuel filler neck and fuel tank for rust - if in doubt replace the neck and flush the tank, before you risk clogging up the fuel system with rust.
Finally, check the spark timing, and the condition of the fuel pump and injectors before you start - my injectors were fine, but the pump was knackered!
Having said all this, VW engines are very strong and built to last - people regularly run them to 200,000 miles without too much trouble, so it should be ok.
HTH
Rich
thank you
cheers,
nery
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Topless Rabbit Forums-VW Cabriolet owners and enthusiasts
hth
rebuild in progress....
sim0n_parker said
600dollers, how much is that in english pounds…anyone?
?285 8O
black 5 door mk1 GTD
mk1 scirocco Gli in bits
