Reverse swing brake pedal
(In Topic #77114)
Could you squeeze these under the dash on the drivers side, and make the cylinders and pipework clear the steering column / electrics / etc…?
This would remove the need for the levers to the original master cylinder, and in addition would allow you to set up the brake balance as you wanted. This may result in superior braking (if set up correctly of course).
Has anyone tried this before? Any thoughts or advice would be very welcome.
Thanks in advance
Rich
But do you reckon will it fit? Or has anyone tried using these on a Mk1?
Thanks for the info
I feel a custom brake conversion coming along
mcscrew said
Sweet 8)
Thanks for the info
Shop around!
Some of the kits will cost you an arm and a leg though some are quite reasonable.
Bear in mind though - If this is for a daily driver, it may be more hard work to drive as you lose the assistance of the brake servo…
My Build Thread
I found Tilton Engineering do a set, but they're about ?600+ just for the pedal assembly 8O. Way out of my price range, although they do look very nice.
I like the idea of fabricating one myself though - this is definitely the cheapest route. al - I may even see if I can squeeze the servo in there too to make general driving a bit easier.
It's all hypothetical at this stage anyway - I still need somewhere to work on the car! (Work in progress there at the mo…)
Rich
Not impossible…
I'm sure I have seen Mk1's in the past with the servo mounted on the drivers side meaning you could bolt it direct to your pedal set-up. Don't think it will fit with the 8V set up though - Manifold gets in the way.
16v on carbs maybe?!?
My Build Thread
I was thinking about a new head (again all very hypothetical) - did VW make a crossflow 8v head for a 1.6?
A 16v head on a 1.6 is too revvy and not torquey enough at the bottom end IMO (carbs could see to that) but I think I'd like to keep it as stock as possible.
