Removing crank pulley
(In Topic #133323)
On the ABF engine I have I want to change the cambelt and remove the cover to change the engine mount for the mk1 one.
The engine is separated from the gearbox as I need to change the clutch too.
How do i undo the 19mm bolt on the crank pulley if the gearbox end keeps rotating too? I've seen the pictures of the spanner and bolts from brokevw but I can't see how to attach it on mine as I haven't removed the flywheel.
I was thinking of reattaching the gearbox so the spline has resistance. How does everyone else do it?
That 19mm bolt DOESN'T secure the crank pulley. Its secured by the 4x hex head bolts. These are invariably tight. The 2 techniques I favour, are:
1) use an impact gun on these. You'll need to clean out the heads so the tool fits deeply within the bolt, and make sure its a decent quality one too. I don't think you'll have much luck with an allen key etc!
2) Simply cut them off, eg with a grinder or Dremel, then replace with new. Once they have been cut and the pressure is off the bolts, removal is far easier, eg grip with mole grips or file 2 flat sides and use a spanner.
Once the bolts are undone, the pulley may well be still stuck. A pulley puller is invaluable for prising it off.
Ah, I managed to undo the 4 allen key bolts with an allen key bit hammered in.
I prised this pulley off
to leave me with this
How do I remove the cambelt cover now?
The pulley is in 2 parts, you've gotten the first part out, the second part is also secured by the same 4 bolts and should now come out - but its stuck due to corrosion. So, use the pulley puller. Careful taps of the hammer around the edge might have the same effect but be very careful not to damage it, hence why the proper tool is much better.
I've had a quick look and it really looks like the 19mm bolt holds that pulley on
The pulley is only held on by the allen bolts you've undone, spray plenty od wd40 around the centre bolt and belt it with a rubber mallet or a dead blow hammer as not to damage the pulley.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
Just been out to the garage and sprayed some WD40 over that centre bolt. I'll have another go at it tomorrow
you may well have to use a puller to get it off, ive been in the same boat. but yep as above deffo 100% that bolt in the middle does NOT hold it on
