removal of fuel injectors...?
(In Topic #139927)
hey,
does anyone know how to remove fuel injectors from a kr 16v, do tou have to remove the inlet manifold or can they just pull out…? cheers sean
they just pull out
Regards Volkswarren
Ok cheers, tried to remove them earlier by pulling them out but had no luck, screwed on an old fuel line fitting and had a pull. will have have another blast, cheers
Member 125 - 2005
There is a tool /bracket you can buy that makes it a lot easier , try a search on ebay
ok will take a look. is it just a case of chapping them in when there to be re-fitted....?
Yes, but best to fit new seals as the old ones go hard & brittle and can be a major cause of air leaks if this happens.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
Will do cheers for the help!
