Rear Brakes locked up.
(In Topic #84198)
the rear near side brake is looked on i can not get the drum off. i have bleed the system. what can i do?
try un adjusting them through the hole at the rear of the drum se hanes manual
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Firstly, before you even start, have you backed off the handbrake?
1st thing - manually push back the adjustment wedge.
2nd thing - if that doesn't do it, sounds like the shoe has come apart within the drum. You'll need to somehow hammer off the drum.
HTH
Rich
Regards Volkswarren
hello!
mcscrew said
Don't be shy with the hammer, especially if the car hasn't moved in a while, as it should loosen any rust or corrosion sticking the shoe to the drum.
HTH
Rich
Should have specified that you should tap the drum on the edges of it with the hammer, not from behind (i.e. from inside the wheel arch) to force it over the shoes.
Only force it as a last resort…
Rich
