quick gearbox question (ABF conversion)
(In Topic #137550)
After 1988 will have the right mounts and driveshaft size
1986-1988 MIGHT HAVE right driveshafts, might not
pre 1986…..best to check driveshafts, most unlikely they're the right ones
small block (1.1/1.3) won't have the right mounts or shift linkage so thats more stuff needed to purchase, or needs adapting etc
16V gearbox will be 100mm outer lip on driveshafts, most Mk1s are 90mm before 1988 etc etc see guide on left and search etc etc
I am converting a gti model so all mounts should be ok?
but to answer the question yes you need a mk2 16v clutch kit. if your mk1 was a 1.6 you'll also need a 210mm flywheel from a mk1/2 1.8. if yours is a 1.8 then it'll have a 210mm flywheel already
Thats good news if I only need the clutch kit as it was a 1.8.
