PLASMA CUT STEEL MANIFOLD BLANKS KR....BIKE CARBS
(In Topic #124414)
HAVE TODAY ARRANGED FOR LONG ESTABLISHED FABRICATION AND ENGINEERING COMPANY TO DRAW UP ON COMPUTER THE PROFILE REQUIRED IN ORDER THAT YOU CAN MAKE YOUR OWN MANIFOLD FOR BIKE CARBS…THIS WILL ENABLE A COMPUTER CONTROLLED PLASMA CUTTER TO MAKE AS MANY OF THESE AS REQUIRED…THICKNESS CAN BE VARIED BUT 6mm IS RECOMMENDED BY THE COMPANY…THE REASON BEING THAT IF TOO THICK IT WILL BEND WITH THE HEAT WHEN WELDED AND WILL NOT BE EASY TO STRAIGHTEN….WITH 6MM PLATE THEY ANTICIPATE THAT THE MANIFOLD STUDS AND NUTS WILL WITHSTAND THE FORCE REQUIRED TO MAKE A GOOD FLAT SEAL WITH THE GASKET…..THE INITIAL COST OF HAVING THE CAD WORK DONE IS OBVIOUSLY THE GREATEST COST, WHICH I AM FOOTING THE BILL FOR AT PRESENT…..I ANTICIPATE THAT THESE SHOULD BE AVAILABLE FOR BETWEEN £30 and £40 each…….stainless will be available at extra cost…
ANY OF YOU GUYS INTERESTED THEN PLEASE pm ME…YOU ARE NOT COMMITTING TO BUY….JUST TREADING THE WATER FOR INTEREST….THIS WILL BE A NON PROFIT SERVICE….WHAT THEY COST ME I WILL ADD ON A COUPLE OF QUID TO RECOVER THE SETTING UP COSTS…….THESE WILL BE PRODUCED IN THE WEST COUNTRY WHERE LABOUR RATES ARE FAR LESS THAN MOST AREAS OF THE COUNTRY…..MANY THANKS
