no spark and fp not priming
(In Topic #146975)
any suggestions?
thanks in advance
Mk1 golf gti
Mk1 golf gti project View topic: 1982 original Irish GTi - The Mk1 Golf Owners Club
mTDI corrado
Mk1 skoda octavia vrs combi
mTDI corrado
also if its digi 1 it needs an ecu relay, if you used a ce1 digi wiring loom as a base there should be a 2 pin plug 'R' to the fusebox, if so then you can fit a #53 relay to the ecu socket. if not then either wire ecu relay above fusebox or just put ecu power feeds to coil live
thanks, any more ideas are appriciated
trouble is digi 1 is quite rare so info isnt so common. moistly its like digi2 when it comes to wiring it in though.
which fuel pump relay are you actually using then? if its a k-jet one that'll work fine just so long as the rev counter wiring from the coil is spliced in properly
