Negative Camber??
(In Topic #78857)
Negative Camber??
**81 1.1L (Insurance Friendly)**
1st project - Any Help Welcome!
Is this what you mean?
Is it in the standard Haynes manual for both the smaller block and big block models?
www.msportcam.co.uk
Understeer whats that?
Lazer alignment..great but I think its kinda of overkill for a mk1.
plus of course mines too low and they cant normally get lazer gear on it ops:
Setting up negative camber is simple. look at how far the cammed bolt on the front strut is turned round and match it to the other side. if something is bent then it will not match when you do this and it will need to be set up properly but if everything is in good cond then this should be fine!
Will
LOL - Your not pushing hard enough!
Any mk1 will understeer if pushed hard enough! :mrgreen:
My Build Thread
As for negative camber, be warned it will understeer, just at higher speeds and when you lift off it will bite you on the arse :wink:
yeah it won't do anygood if the chassis is bent !
as far as running loads of negative camber….. why do it too much you want to wear tyres out quicker ? more doesn't mean it's better !
www.msportcam.co.uk
I drive a lot of country lanes and loved it when i had silly maxed out negative, but was nasty to drive on motorways .
I reckon neg about 1/2 to 1 deg would be spot on.
http://img65.imageshack.us/img65/2838/s5000021agm0.jpg
Rich_M said
Get a spirit level and hold it against the bottom of the wheel rim verticaly and measure the distance between the top of the rim and the level, get both sides to match and jobs a good-un. Make sure the car is sat level first tho :roll:
Will need to check tracking after doing anything like this though…
You could do it all by eye like I did!
My Build Thread
Cheers again
