need help
(In Topic #107067)
need help
engine is spitting oil from carb ,spraying from drivers side back of engine and hard starting /staying started so thinking of swapping engine.
i have a budget of about ?700 to get it running again wot would be the easiest engine to put in and would it require any moving things about in bay? would prefer a bigger litre ,
can anyone advice?
clive
So, just find a replacement 1.3 engine and fit it.
so would it have to come out of a mk1 or is ther anyothers i can gt ?
5p4mmy said
ok thanks
I don't know, I imagine MK2 Polo or Mk2 Golf have similar engines too but you're better asking the small block carb experts.
the transplant is so strait forward the wireing put me off abit but is easy once you have it all laid out you only realy need the ecu and fuel pump wires and you wont have to cut and move the drivers side engine mount.
gaz
keep on dubbing
