My Golf Mk1 GTI 2.0L 16v G60
(In Topic #111986)
With 260bhp from 2 litres, in a Mk1 Golf, and it not being fast enough for you ………………. exactly how fast do you want it? I assume not top speed, so are we talking acceleration?
All seems a bit pointless in a mk1 though, it'll just be lighting up tyres!
4x4 conversion?
I am wondering - does it really need to be a Mk1? And also, at around 300-350bhp the benefits of a PROPER 4wd system (not just Haldex) is good to have, and outweighs the additional weight/complexity/hassle/cost. If not a Mk1, then does it need to be VW Golf? If so then a Mk2 with R32 conversion might be more sensible. If not VW, then there are 'off the shelf' cars you can seek new or secondhand with the power/weight ratio to beat your current car - for example the higher end Porsche 911 models, Caterham, possibly modified Subaru Impreza, etc. All of which are designed and engineered to a high standard and will handle the power quite well.
Depends really how sentimental you are towards the Mk1 and how much money you have.
a mate was getting 260bhp with maxxed out injectors, incorrect cam timing, and ignition timing set well below the standard 6 degrees BTDC from an 8v G60.
what is the base engine? i've seen 303bhp from an ABF based 16v G60 - that's using standard internals and stacked head gaskets!
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
was the most fun car ive had yet.
what about a different charger?….
