mucho helpo needed please
(In Topic #139776)
i have a 1.8 carbed petrol 1988 cabby,
i have just brought a 1996 vento 1.9tdi, i beleave a ahu engine,
IAM GOING TO HAVE VERY LITTLE TIME TO DO THIS SO NEED AS MUCH INFO AS POSS TO MAKE IT QUICKER
i want to transplant the engine and box, which means converting the cable clutch to hydro and converting the push rods to cable select on the box, oh and the fly buy throtle jobby ANY INFO ON THIS WOULD BE HELPFUL but im sure i will sort out when it comes to the doing part of the job
my main consern is the wireing of the engine and ecu, DO I NEED TO TAKE THE WHOLE LOOM OR CAN I PATCH IT IN TO MY EXISTING LOOM
ANY HELP OR LINKS TO INFO WOULD BE VERY HELPFUL,
i have been told some one did it to a mk1 caddy and made a good tread but i cant find it anywhere
PS I WONT BE SALEING THIS AND BUYING A AAZ ENGINE SO PLEASE DONT WASTE TIME TELLING ME TOO,
only 2 tools needed, wd40 & ducktape, if its stuck,wd40. if it needs sticking,duck tape ;p
wiring wise you'll need the complete engine loom, then splice the mk1 fusebox plugs on it after tweaking the routing. its best to start with another mk1 engine loom, keep the mk1 specific stuff and add in the mk3 stuff. you can do this before you start stripping your car down as well.
fuel system wise i think you can just keep the carby tank and sender unit, though you'll need to clean it all out really well and find somewhere to put the diesel filter, i think the mk3 one will fit quite easily though as its a small inline unit afaik. have a look underneath anyway you'll soon spot it
well i feel i need to do a bit more reserch before i start as it will need to be done over a weekend and maybe a couple of evenings etc as the cabby is my daily drive and im stuck with out it
thanks again for the input fella, and any more info all helps guys
i will do a nice detailed tread when i do the converstion for any future people looking, the aaz must be getting short supples soon
wiring loom is pretty simple once you break it down i have all the diagrams you need in my sig. look at jetta89 for your fusebox, its mk2 golf but your car will be similar, plus look at the fusebox sticky.
you could fit the whoel car loom if you want but it would be a lot of work since the fusebox is on the opposite side of the car, unless you drill a hole on driver side and mount fusebox there.
not sure on the mk3 pedal box to mk1, the guy might have foudn it easier by fitting the complete dash as its all kinda integrated together. depends what you want really. i prefer the mk1 dash personally, trouble is findign a mk1 diesel rev counter dash i imagine thats going to be tricky!
