mk3 caliper adaptor brackets - anyone else sell em?
(In Topic #96135)
I just want my toy back on the road, I need a new small battery too, or to move it to the boot, as my finished cold airfeed is in the way but ill deal with that later.. ill find a way…
Not the best kit in the world fitment wise, but were well made apart from the allen key bolts, used to attach the caliper bracket to the custom brackets, they are too soft in metal composition.
Golf Clipper 1.8 Carb F Reg in Blue
mods and work so far:
mk4 rear disk
vr6 calipers and g60 disks
9" servo and 16v master cylinder
h&R adapters and d90?s 6" front 8" rear
webber carb
inlet manifold, rocker cover & exhaust mani gaskets
mk4 rear disk
webber carb
what makes you say the bolts are to soft?
just wondered as i'm about to order some, not heard any negitive feedback :dontknow:
To cut the cost they supply the kit with the wrong spec bolt. On the head it should have 10.9 on it. its a highly stressed bolt so it needs to be a good grade. Alot of general bolts are 8.8 grade but suspension and braking area's use 10.9
You can buy them from a good supplier yourself if you still want the kit.
Just leave the bright shiney bolts they supply for holding on air filters and not your brakes mate!
Domma,…………..
g40'd ratter
<div><embed type="application/x-shockwave-flash" wmode="transparent" src="http://w139.photobucket.com/pbwidget.swf?pbwurl=http://w139.photobucket.com/albums/q312/Forgeman/75e604af.pbw" height="120"
what do track day cars run?
You don't need to up the value just match it.
Take a look here for some info.
http://www.namrick.co.uk/
Domma…………
