mk3 1.4 into a mk1
(In Topic #125442)
mk3 1.4 into a mk1
the question is: Is a mk3 small block engine (which i'm guessing the 1.4 is) going to have the same mountings as a small block mk1?
because mines a 1.1 so i no all the tank would need changing to injection stuff but i dont mind that its just the welding side of things thats stopping me wanna do a 2.0L conversion plus thought it'd be something a bit different! any helps much appreciated
Many thanks!
My Current Collection:
1980 Mk1 Scirocco Storm.
1982 Mk1 Golf Carbon Berg-Cup 16v (Frankenstein).
1996 Mk3 Golf GTI 8v Anniversary 3dr.
2002 Mk2 Caddy Van PD130 (Berg-Cup Support Van).
1982Mk1Golf, you'll have to modify your driver's side engine mount to accomodate the engine, as it's a small block and the mount needs to sit further forward on the chassis leg. I'd have the exact opposite problem if I wanted to install a GTi engine into my 1.1. On the bright side you have a choice of much bigger engines and you could sell the 1.4 fairly easily.
Oh, and you'll need a boss for the lambda probe welding into your exhaust, or use the mk3's one (but it has a cat convertor in it)
gt cam will only work if you get some kind of electronic fuel pump, so that'll have to be matched to whatever management you decide to use.
re: fuel tank MK3 one wont fit so you'll need to get a MK1 tank, carby tank is fine even if you plan to go injection because you can just drop a MK3 Polo or late cabby/scirocco lift pump into it plus the fuel reservoir and main pump from the same car.
food for thought anyway
and a polo gt cam and engine management system which will just plug straight in the mk1 fuse box?
So by looks of it the only decision im left with is what gear box to use as my current mk1 box is only 4 speed and i also need to pick up a set of gti calipers and disks to make it stop
but tbh prob easier to just get the right electronic fuel pump. I would fit the in-tank pump off a mk3 polo or late cabby/rocco, as well as the under car plastic reservoir to prevent fuel starvation from the same car. may as well get the main pump, filter & lines etc from the donor car as well, even if you dont use em right away they're handy for runnign EFI from say Polo GT lump or G40, even 2.0 16v ABF etc.
Polo GT cam swaps right in, the head on the 1.4 is actually same as on the GT as well which is nice. It wont plug into your fusebox, you'll need to adapt it for your car. If you dont like the sound of that I can make a loom for you, just post me the GT loom and your old engine loom and I'll work my magic
its not too hard though, once you strip out all the non engine specific gubbins there are only a few wires to hook up and you're away!
The 8P box is a good one to have, or just use the one that comes with the 1.4 block. any 5 speed polo box will work too. dont forget you need the GTI carriers and pads too
