mk1 s3 conversion
(In Topic #82321)
mk1 s3 conversion
s3`
if so then your going to have your work cut its not the easiest conversion to do in a mk1
20vtmk1 said
thought so is there no way of changing 4wd to fwd?
You could use the same gearbox as other FWD VW/Seat cars with 1.8 20vT engines. I think there's a bit of fabricating gearbox mounts, and you'd need to convert to cable-change gearbox too. I am sure sooner or later, someone will be along to advise of specific gearbox codes which could be used and which donor cars they could come from.
paul_c said
Who cares? what about 4WD to RWD? A rear drive Mk1 Golf would be awesome. Anyone done it?
If my memory serves me right, yes a rear wheel drive mk1 has been done.
Check out www.http://www.golfgti.co.uk features theres a TVR powered MK1 8O
