MK1 KR on carbs - correct ignition distributor help?!
(In Topic #129408)
Can smeone point me on the correct dizzy to use wihout ecu/tci for my engine with carbs?
I use now one from a fiat uno with two wires and vaccum.
d0 1t w1th 5t1l3
Edit; this s the best pic I could find of the one you need. They're not the easiest to find but they pop up on ebay every now and again, or Saab breakers are the best bet…
But you can use the KR distributor along with the KR ECU! The KR ECU has a vacuum inlet so that it can control timing directly, so you can just link the vac take off from your inlet manifold straight to the ECU
I found one of some seat (made in spain) with 3 pin connector, but i have only two wires. traying all combination of wiring - no spark
send pics in one hour…
d0 1t w1th 5t1l3
