MK1 GTI Mod suggestions
(In Topic #89659)
Fancy a few mods on my Mk1 GTI (1.8 / 9A box). Nothing too mental, just some extra torque for blasting round track days at Knockhill. Can anyone recommend any?
Does the larger throttle body actually make much difference?
JimbobJones said
buy a 2ltr 16v mk3 golf and engine swap :twisted: sorry ops:
Can't be done with ?500 - well it could, if you cut corners on the job.
saying that yours is already a 1.8 inj so you may not need all that, you may be able to just swap the heads?
i haven't done the swap i've just read about it and intend to put a 16v in my caddy so don't take this as gospel but i hope it helps until someone more knowledgable corrects me :roll: :mrgreen:
engine swap.
If your looking at doing occasional track days, I'd spend the cash on getting the running gear up to spec (incl the brakes…), possibly get your current motor lightened / balenced fit an Audi throttle body and WUR (does make a difference) and free flow exhaust if you haven't already got one.
Good luck for whatever you decide though.
J
the above comments are the individuals only and in no way represent the best way forward…
ManicGTI said
Surely 2L bottom end and some head work is doable for ?500….?
Either is do-able (staying with 8V), but not both. Would you want head work without a larger throttle body and exhaust?
How hard was your 20VT to shoehorn into your Mk1?
theres about 1200000 pages on it already!
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=4534&highlight=20vt
rebuild in progress....
