mk1 golf project
(In Topic #106811)
mk1 golf project
i have a 1.1mk1 golf a reg
with a 1.3 mk2 driver engine but is nw dead so needing a new engine i have no idea where 2 gt a complete engine from n wot else is needed 2 gt it going again was thinking of putting a 1.8 8v mk2 engine in any advice???
many thanks clive
is there any other bigger engine i can gt to drop straight in??
that's not really going to offer you much performance over your mk2 1.3 engine - plus you'll have to cut the driver's side engine mount from the chassis leg and move it back a few inches and weld it back on, you'll need a steering rack from a big block mk1 (1.5+) or have to modify your current rack to suit. you'll also need the gear linkages and driveshafts from the 1.5 as well.5p4mmy said
also i have jus spoke to a friend who has a mk1 1.5 4 speed jetta engine do u know how much work this will be to fit?
like paul said, a like for like swap is probably your best bet. those mk2 small blocks are normally pretty bombproof.
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
only reason was cause i was getting the complete engine cheap with low millage so is there a bigger driver engine i cn put in or do u rekon stay with the 1.3?
many thanks
polo GT
polo 1.4 16v
polo 1.6 16v
also, if you wish to run the 5 speed gearboxes with these polo engines you'll need to custom fabricate the gearbox mount for the passenger side.
so if i gt the polo gt engine would i need 2 move anything else apart from gearbox mount or gt anything else or will al my old parts be ok?
does anyone have any good sources to bye complete engines from also many thanks
