mk1 golf polo 1.4 8v engine conversion
(In Topic #111672)
i have been asking everyone about performance bits for 1.3 or how easy it is to swap a gti 8v engine into my mk1 driver
but i have come to the conclusion that it would be easier and cheaper for me to put a 1.4 8v 6n polo enigne into my mk1. 8v beeing the easiest one to find cheap . i intend to put gsxr 600 bike carbs on it to cut out the faffing with elec injection .i know you need to fabricate a mounting for the 5 speed box which doesnt look to hard .iam also planning to cam it.
i was wondering if anyone has done this b4 ?
which driveshaft do you use?
which linkages do you use?
and what ignition gear shall i use ?
thanks very much!
i have made up my mind i promise!
the 1.4 block has lower compression but gives a bit more torque, i have heard its worth the extra effort, as for the gearbox i was planning on using the 4 speed 8O so it wouldnt of been an issue but you will need to frabricate an extra mount i belive
i'm sure someone else will be along soon to correct me and fill in some gaps, oh and dont worry abount not makin your mind up - i still havent!!
